UX Problem with Interface Filter
  • September 19, 2023
  • 41 views
When using the interfaces in Airtable, I face a strange problem. When I create a new interface, I can set a filter. When I like the interface, I would like to duplicate the interface, but with a different filter. How can I do this? Thank you!, Simon
Zack_S
In your interface builder select the page on the right side of your screen (there are three dots) click duplicate and then change the filter.
Thank you. But where do I change the filter? I know it must be right in front of me, but I cannot see it.
Zack_S
  • September 20, 2023
Depends on what type of interface you are using. Should be in the settings on the right side of the page when you select the interface.
Here is a resource that might help.
https://support.airtable.com/docs/interface-element-filter
