Aug 16, 2022 08:29 AM
Hello
Can someone give me an advice?
Sorry, but my english is not great to explain everything as I want.
For a restaurant, I have recipes, with ingredients, and they came for vendors.
What is best? 3 bases linked, or just 1 base with everyting?
The 3 bases, that look logical to me, are: recipes, inventory, and vendors.
Ingredients is the only thing that must equal in all the 3 bases.
But I never did any base, so maybe I’m thinking wrong.
Thanks in advance
Solved! Go to Solution.
Aug 16, 2022 08:42 AM
Hi @frank_laureano ,
Welcome to Airtable Community !
You’re English is good enough no worries :slightly_smiling_face:
The idea of 1 base or 3 bases all depends on the amount of data you have. I always recommend 1 base for everything. But if you think you will have more than 50K records (assuming you are on the Pro plan) then I would recommend 2 bases (not 3). One for recipes and inventory, one for Vendors (that you will sync to the other base)
Aug 16, 2022 09:17 AM
Thanks
So I will try 1 base.
Time to study how to do that!
