Assigning Values to attributes in a Multi Select Column
4480 5
Phil_Borreson
I have a database with a multi select column filled with attributes that contribute to a ranking. I would like to create a formula that finds and assigns a number value to the attributes in the multi select column. I have been able to accomplish this with one variable in a test scenario; however, the real data has up to 30 possible attributes per record that contribute to the ranking. Any recommendations on how to create a nested if find statement that looks at a multi select column and returns a custom assigned number value to the found attribute/s?
5 Replies 5
Have you thought of using a lookup table instead - you can simply change the multi select field into a Link field. Then add a numeric field to the lookup table and use a rollup field to total the values in your original table.
Phil_Borreson
Interesting suggestion! As we have many attributes, would the look up table need to include every possible combination of attributes, or take each one separately if separated by a comma?
Here’s 2 tables:
This table had colors (multi select) converted to Linked to another table.
MultiSelect2Lookup - 1
This is the table where it’s linked to.
MultiSelect2Lookup - 2
So, the figures will be seperated by a comma.
@Andre_Zijlstra - that is largely what I was thinking but if you use a roll up field instead of a lookup then you can total the Values associated with each Category.
Good point!
Lookup-Rollup
