Base Permission - Possible not to have collaborators copy a base?
  • July 24, 2018
  • 11 replies
  • 106 views
Kim_Trager1
Forum|alt.badge.img+23
Im making a airtable system, for a friend of mine.
It deals with quite sensitive data…
Is there a way to make sure an editor can’t just duplicate a whole his base including all records into their own workspace, but still be able to edit records?
  • October 31, 2018
Did you ever get a response to this issue? We’re facing the same dilemma
Kim_Trager1
  • October 31, 2018
Unfortunately not.
We’re sofar working under the pretence that no-one would ever think of it being an option… And sofar it haven’t been a problem.
But guess it’s like an insurance; you never need it until it’s too late…
  • February 4, 2019
That’s crazy. It’s a huge security issue. That way the sensitive info of clients can be easily duplicated multiple times by multiple (nested) invites. I cannot understand why Airtable does nothing about it. No need to be genius to steal the whole CRM
  • February 4, 2019
your question is sub-feature of a major long running feature request Advanced User Permissions
  • February 6, 2019
thank you Michael. Do you know if it is possible to see whether the base has been copied? Some kind of history
  • February 6, 2019
I’m pretty sure no, but I’d suggest you try to copy a base with multiple users on it and see if anyone gets a notification that they are part of a ‘new base’
  • March 7, 2019
It is a big problem for us, I can’t understand why we don’t have a way to block “duplicate base” feature.
Is this still an issues in 2021?
If so, this needs to be addressed. This is kind of a deal breaker.
Kim_Trager1
  • January 20, 2021
I’m actually not sure, I’ve just continued on the assumption that no-one would do such a thing… :grimacing:
I agree, and in a GDPR context, it’s uncompliant :upside_down_face:
  • July 3, 2021
Yep, it’s one of the major security holes in Airtable (yes, there are more of them).
You could use a portal tool like MiniExtensions.com to create a more secure user frontend for Airtable, but then you lose all of the interface benefits & most of the features of Airtable.
I would recommend that people keep emailing support@airtable.com about this issue. Although it’s been 6 years and they haven’t cared enough to address this issue, so it’ll likely never happen.
