Hello all.
I am hoping to organize my backpacking gear with AirTable. Weight is an important attribute of each item.
What’s the best way to add a field for weight? Ideally, I would like to set up the field so it could calculate both lbs and oz. So 18 oz would recalculate to 1 lb 2 oz.
Is that possible, or should I just keep things simple and record everything in ounces?
Thanks for your help.
Hello!
Organizing your backpacking gear with AirTable is a great idea, and you can certainly add a field for weight that can calculate both pounds (lbs) and ounces (oz). To achieve this, you can use a combination of two separate fields: one for the pounds and another for the ounces.
Here's how you can set it up:
  1. Add a field for pounds: Create a number field and name it "Pounds." In this field, you will enter the weight in pounds (e.g., 1, 2, 3, etc.).
  2. Add a field for ounces: Create another number field and name it "Ounces." In this field, you will enter the remaining weight in ounces (e.g., if the total weight is 1 lb 8 oz, you would enter 8 in this field).
  3. Calculate the total weight: Create a third formula field and name it "Total Weight." In this field, you can use the following formula to calculate the combined weight in pounds and ounces:show more
