I created a automation “When record is created” and added an action to create another record in another table - the new record in the other table should get field values from the created record in step-1. The automation does not take those values from the record - they are empty. It seems that the record of step-1 is not created yet (like a DB commit). Other field values that are set with fixed values are taken into the new record, but every field that should be taken from step-1 are empty :frowning: Any suggestion what is wrong here?
Create Record action in a create record automation does not work
