Hi @Villani_Lab
There are some fields (formulas, date, etc.) that will not convert to the original field after a CSV import.
There were times when I would have really needed that to happen (the fields to remain the same), but, unfortunately it did not.
In terms of the columns, when you do a CSV import you have to make sure that the columns that you import have the the headers and in the correct sequence i. e. DATE, ADDRESS fields in the base, should match, and be in the same position as the CSV file. If the CSV file does not have data for all fields, you could just include the field name only, with no data. This way headers in both the database and CSV file will match.
Hope this information helps.
Mary K
Hi @Villani_Lab
Mary K
From what I read,@Villani_Lab is looking to export a CSV file, not import it, and is talking about the difference in exported data depending on whether he’s viewing it as an authorized user or in a read-only context.
@Villani_Lab I haven’t seen that kind of difference before, but then again I haven’t done more than a couple CSV exports. If you haven’t already done so, I suggest contacting Airtable support about this.
