Hi There,
I’m new to Airtable - and it is awesome.
One thing I am having trouble is being to make something very easy for my team to understand with the same dataset.
Basically - show list of data in one view as one table - (e.g. sheet1) and have another view that is the Kanban view as another sheet (eg. sheet 2).
I was trying to set the data in Sheet 2 = to Sheet 1 - as if I were doing a direct link in Excel - but it doesn’t work that way.
What is the recommended way to handle this?
How do you try to type in a formula to pull data from another sheet?
How can I have multiple views be available for the same dataset as separate sheets (that is - not have to change the view of the dataset I am looking for - show the views are always available as separate tabs).
Thanks in advance.
