Jul 24, 2021 04:30 PM
I’m not very tech-friendly, so I’m not sure what the best way to go about this request would be - any advice is very much appreciated!
I keep all of my orders in a table - each individual birthdate is imported with each order in its own column (DOB). I would like to find a solution to automatically update a separate column (ZODIAC) with the corresponding Zodiac sign depending on the day/month of birth.
I can’t seem to make it an automation in Airtable with if/then parameters because I can’t select a date range without the Year included.
Does this make sense? Any tips?
Thanks in advance!
Jul 25, 2021 06:01 AM
Hey @Taylor_Johnston,
You can change the ZODIAC field to a formula field and use the following formula in it:
SWITCH(MONTH({DOB}),
1, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 19), 'Capricorn', 'Aquarius'),
2, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 18), 'Aquarius', 'Pisces'),
3, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 20), 'Pisces', 'Aries'),
4, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 19), 'Aries', 'Taurus'),
5, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 20), 'Taurus', 'Gemini'),
6, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 21), 'Gemini', 'Cancer'),
7, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 22), 'Cancer', 'Leo'),
8, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 22), 'Leo', 'Virgo'),
9, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 22), 'Virgo', 'Libra'),
10, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 22), 'Libra', 'Scorpio'),
11, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 22), 'Scorpio', 'Sagittarius'),
12, IF(AND(DAY({DOB}) >= 1, DAY({DOB}) <= 21), 'Sagittarius', 'Capricorn')
To elaborate a bit on how the formula works – the idea is to split each month in two and assign a sign to each part. For example, January 1 to 19 is Capricorn and the rest of January is Aquarius.
Jul 25, 2021 10:36 AM
@Raminder_Singh
Raminder, I should have known I could count on you!!
Thank you so much. :slightly_smiling_face:
Jul 25, 2021 11:34 AM
Since the day will always be at least one, the formula can be tightened up a bit:
1, IF(DAY({DOB}) <= 19, 'Capricorn', 'Aquarius'),
2, IF(DAY({DOB}) <= 18, 'Aquarius', 'Pisces'),
3, IF(DAY({DOB}) <= 20, 'Pisces', 'Aries'),
4, IF(DAY({DOB}) <= 19, 'Aries', 'Taurus'),
5, IF(DAY({DOB}) <= 20, 'Taurus', 'Gemini'),
6, IF(DAY({DOB}) <= 21, 'Gemini', 'Cancer'),
7, IF(DAY({DOB}) <= 22, 'Cancer', 'Leo'),
8, IF(DAY({DOB}) <= 22, 'Leo', 'Virgo'),
9, IF(DAY({DOB}) <= 22, 'Virgo', 'Libra'),
10, IF(DAY({DOB}) <= 22, 'Libra', 'Scorpio'),
11, IF(DAY({DOB}) <= 22, 'Scorpio', 'Sagittarius'),
12, IF(DAY({DOB}) <= 21, 'Sagittarius', 'Capricorn')
