Help with permissions
  • February 11, 2020
  • 26 views
Hi, I want to give my collaborators Editor-level permissions to only some Views in my Base, but I only seem to be able to give this permission level at the Base level, rather than per-view.
I seem to be able to share individual Views as “read-only” (via links), but not with Editor permission.
Is this a restriction of Airtable?
  • February 11, 2020
Afraid so. You can really only close off portions of a base via the read-only links (they can also use forms to add one row of data at a time).
If the data isn’t sensitive, you could try encouraging other users to create private rather than shared views. But permissions and view clutter have both been pain points for my team.
Someone motivated enough could try linking up multiple bases to get around all of this. But that’s an undertaking that involves external tools.
  • February 27, 2020
I’m trying to determine how I can give the editor the ability to sort and view the data as they choose, but limit the ability to edit records. Collaborators can view but can’t sort and such. Is there an advanced permission level I can tweak…I assume not, but I thought I would ask.
  • February 27, 2020
Have a look at the permission docs
