Interface - number element resizing?
  • November 19, 2021
  • 85 views
Hi. Is there a way to change the size of this element? It has resizing handles but I can’t get them to do anything. Thanks.
Best answer by Justin_Barrett
I haven’t run into any issues with any resizing handles…well, sort of. If you’re trying to make the item smaller, you might have hit its minimum size. One of my main frustrations with many elements is that I’m not allowed to scale them as small as I want.
  • November 21, 2021
  • November 21, 2021
Yes, trying desperately to make them smaller.
  • February 2, 2023
+1 to needing certain elements smaller. Especially Number elements.
Also Left, Center, and Right justifications on Text element.
Cori_Kennedy
  • March 2, 2024
How was this solved?
