- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
Jul 08, 2020 12:56 PM
Hi Airtable
I have an Integromat scenario to backup Airtable records, but it does not seem to work. I keep getting a RunTimeError. I am also not getting the Multi select options for each record, filled in each field.
Can someone take a look? Maybe @ScottWorld?
Here are screenshots of the scenario and error.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jul 08, 2020 01:25 PM
Hi @M_k, It looks like your problem is that you have an empty module starting your scenario that does nothing. Delete that module, and schedule the “Search Records” module instead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jul 08, 2020 01:58 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jul 08, 2020 03:52 PM
It looks like it’s having a problem with your “Stamp Format” field in the destination Airtable table. Does that field happen to be a multi-select or a single-select field? If so, you’ll need to turn on “Smart Links” at the bottom to make that work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jul 09, 2020 07:06 AM
Hi @ScottWorld
I figured out how to setup the multi select field in Integromat. Thank you.
I have two multi select fields, in total, and I wondered how to set it up for both, since I was only able to get it working for one field.
I also want to copy records from one database into another, different database with this scenario. Can it be done and how?
Thank you,
Mary
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jul 09, 2020 07:16 AM
Yes, but you have to specify each field… you can’t just say “copy this entire record”.
