Pivot Tables Multi-Level and Date Variable
  • March 27, 2020
  • 37 views
Hello, is it possible to create a pivot table that has date variables as well as category tags. I work in sales and I’m trying to sort my CRM data reporting to sort by week and count e.g. how many calls, how many pitches, how demos etc. At the moment I have one column in grid view that has the various client interaction tags for each individual client. I would be so grateful for any help!!
Mohamed_Swella1
Hi @Francis_Rodino,
Welcome to Airtable Community !
If you are Using Airtable Pro, you can use the Pivot Table Block and group your records by categories for example.
But since you are looking to see the data in a chronological way, I believe the Charts block will be even better.
BR,
Mo
