Problem to filter correct by date
  • January 24, 2022
  • 34 views
please who can help me…
dates are not correctly sorted
I’m in Belgium using day/month/year
but than the numbers go from
this is the problem
  • January 24, 2022
Airtable thinks that your dates are month/day/year and is sorting them that way.
You can look at at the field configuration to change the format for how you want dates displayed.
  • January 25, 2022
Can Airtable add this as request so it is able to correct sort…
thx for your answer
Karel
  • January 25, 2022
thx for your answer
Karel
Can you share a screen shot of the configuration of the date field that shows the formatting options for the date?
