Sorting records for MAP display points on dealer location map
62 4
theskiffguy
dealerapp.jpgWhat is best practice to sort records for inclusion in a map ?  I used a multiple choice checkbox but cant get anything to work.  I have a database for dealers for a product and one of the fields is "STATUS" this is a multiple choice field...if it is checked "ACTIVE" (active dealer) I want it to show on the map, but not the others.....
Please help a newbie to Airtable
4 Replies 4
Hm, I'm assuming you can pick which view the extension displays data from right?  May I know what happens when you create a view with a filter that only displays the records with "ACTIVE", and then use that view in your extension?
Timesaving- I only have it with one view at present- Im a total Airtable newbie and just trying to figure stuff out and not confuse myself.  I posted on here so Id not get too deep into this and have to start deleting lots of things or start over.... so is using different views the way to go ?
Yeah if I were you I'd try it
theskiffguy
ANYONE ELSE ?????
