Oct 25, 2020 07:42 PM
Hello!
I’m building my online store using WooCommerce (on Wordpress.) Trying to think ahead a little bit, regarding how to manage inventory.
I’ll outline some points of consideration, using numbers for the community to easily reference when responding:
I will look forward to any feedback. Hopefully, I’m not the first person who uses Airtable, that would like to do this!
Oct 25, 2020 08:11 PM
Typically, if people don’t want to manually script connections between platforms using those platforms’ APIs, people turn to external no-code automation platforms like Integromat or Zapier to communicate between platforms.
Zapier doesn’t have full Airtable support — but Integromat DOES have full Airtable support — which is why I can only recommend Integromat.
Integromat also has very extensive WooCommerce support, and its WooCommerce support is significantly deeper than what Zapier offers.
So it seems like Integromat is the slam-dunk solution here, since it has full Airtable support and likely full WooCommerce support.
Note that I am a professional Airtable consultant and a Registered Integromat Partner, and the Integromat links contain my personal referral code.
Oct 26, 2020 06:56 AM
Thanks for the tips, Scott!
I actually have another scenario already set up with Integromat. Seems like I would quickly surpass the FREE threshold if I’m having the scenario run every 5 mins or so. :thinking:
I may DM you to inquire about doing some contract work for us. :pray:
May 03, 2023 07:36 AM
As an alternative, you can use a 3rd party tool to connect Airtable to Woocommerce. Try Skyvia - it is a no-code data integration product with a freemium model.
