Syncing tables within the same base
  • March 11, 2022
  • 3 views
Hey there!
I have created a base for my Social Media Calendar in which I have a “master” table and then a separate table for Instagram, Facebook, etc. I duplicated the master table to create the others and selected to duplicate the records as well. On the master, I have a field where I select each of the platforms the post will go into. And then on each of the separate tables, I filtered that field to show only the posts that go in that platform. My issue is that, when I create a new record on the master, it’s not automatically filling them in on the separate tables. Is that not an option? I have it set up this way, so I can go on the separate tabs for each platform and indicate which time a post should be scheduled for since I post to Instagram at a different time than I post to Facebook, etc. I don’t want to have to create multiple lines, just to show the different post time. Any suggestions would be greatly appreciated!
Jenna
