Team plan with max 3 editors
  • August 27, 2024
  • 0 views
We currently are exploring if Airtable is suitable for us (small agency). As part of my investigation I ran into the upgrade options to 'Team plan'.
While we only intend to have a very limited amount of editors/creators (max 3), but do like to added functionality of the Team plan, it seems impossible to reduce the amount of (6) seats in the Team plan.
In my case, with 3 intended seats, I would pay minimal $40,-/seat/month (annually).
How can I get a Team plan for 3 editors and unlimited commenters?
Thanks for helping out 🙂
Pascal_Gallais-
You could have a team plan with only one editor, there is no minimum number of editors' licenses.
Since you are upgrading your plan, you may want to check how many editors your have on your current plan and reduce it to three before upgrading.
Regards,
Pascal
