Sep 11, 2021 05:17 AM
Hi everyone !
I have a personnal plan plus and 1988 dollars credits on it.
I want to upgrade to the Pro plan (20 dollars, paid yearly).
The only thing is that i’m afraid to lose my beautiful credits if i upgrade …
So i want you to ask if the credits are saved when you upgrade your plan :thinking:
Thank you
Solved! Go to Solution.
Sep 11, 2021 06:44 AM
The Pro plan is $20/user/month when paid yearly. Thus, it would cost $240 if you upgrade to a yearly plan. If the credits are already in the workspace, they will be spent on the upgrade. If the credits are tied to your account but not yet assigned to a workspace, you can upgrade without using the credits. However, why wouldn’t you spend the credits on the upgrade? You can’t use the credits for anything else but Airtable.
Sep 11, 2021 06:55 AM
Tanks for the answer !
I did it, perfect !
Sep 12, 2021 12:41 AM
Typical billionaire behavior, they just want to flaunt their wealth smh :grinning_face_with_sweat:
