Using IF within a CONCATENATE formula
  • September 8, 2019
  • 8 replies
  • 151 views
Forum|alt.badge.img+13
I need some help using an IF statement within a CONCATENATE formula. I have tried many permutations but have just not found the right syntax.
I have the following fields:
  • AirtableID
  • CompanyName
  • Project
  • Sub-Project
  • Person
In the Name field of a table, I want to concatenate these fields as such:
If Sub-Project is not NULL, then Name = AirtableID_CompanyName_Sub-Project_Person
Else (Sub-Project is NULL), then Name = AirtableID_CompanyName_Project_Person
Here is as far as I got, and I know the syntax is not right:
CONCATENATE({AirtableID},’’,{CompanyName},’’,IF({Sub-Project} = 0,{Project},{Sub-Project}),’_’,{Person})
Best answer by JonathanBowen
Slight amendment as project is not included when sub-project exists:
  {Sub-project},
  {AirtableID} & '_' & {CompanyName} & '_' & {Sub-project} & '_' & {Person},
  {AirtableID} & '_' & {CompanyName} & '_' &  {Project} & '_' & {Person},
JonathanBowen
Hi @Sharon_Visser - I tend to use & rather than CONCATENATE as it is a bit easier to read (IMO), but you’ve totally got the right idea with this:
There’s a few ways to express this, but this one reads the same as your pseudo-code:
  {Sub-project},
  {AirtableID} & '_' & {CompanyName} & '_' &  {Project} & '_' & {Sub-project} & '_' & {Person},
which reads as "If sub-project exists, then ‘first line’, else ‘second line’ "
JB
JonathanBowen
  • September 9, 2019
  {Sub-project},
  • September 9, 2019
Thanks so much Jonathan - I had to remove that last comma, but otherwise its exactly what I needed! And I agree that & is much easier to read than CONCATENATE. The way you wrote it out in the IF statement is logically how I think about what I wanted it to do. I also figured out a way to embed the IF statement, but your way is much cleaner so I am going with that. Thank again!!!
JonathanBowen
Yes, you’re right - an extra comma at the end that’s not needed!
Graham_Lindsay
  • May 28, 2022
Thanks, this is the solution I was looking for too.
  • May 29, 2022
  {Sub-project},
JB
So, is :&” the same as CONCATENATE?
  • May 31, 2022
Yes, you can use “&” instead of CONCATENATE:
If you have fields: ‘First Name’ and ‘Last Name’, you can combine them to create “Full Name”
  1. {First Name}&" "&{Last Name}
  2. CONCATENATE({First Name}," ",{Last Name})
Both will give the same result. I just find using the “&” to be easier.
  • January 16, 2023
  {Sub-project},
was looking for this solution for HOURS and finally figured out how to re-work my formula!
