Using Integromat to change view filter settings
  • December 28, 2021
  • 34 views
Can I use integromat to change the filter settings of one particular view?
I use different views to trigger certain integromat scenarios and it would be great to be able to trigger or turn off scenarios via integromat changing the filer settings of an individual view.
Thank you for your wisdom, friends.
Best answer by ScottWorld
No, you can’t change filter settings via the API. Filters must be manually changed by the user within the Airtable interface.
  • December 28, 2021
  • December 28, 2021
Thx Scott
Appreciate the swift response.
