Omni icon not appearing
  • June 30, 2025
  • 329 views
Forum|alt.badge.img+8
I am trying to access Omni but the icon does not appear in the upper left corner of any of my bases. I am on a Business plan with 20,000 AI Tokens per month available. What should I do?
Best answer by Arthur_Tutt
Actually I found it - go to Airtable’s press release page on Omni here and click the ‘Try Now’ button. You’ll then pick one of your workspaces to add omni too, and will kick off the Omni flow to build a new base
https://www.airtable.com/platform/app-building
MilhoanDesign
Forum|alt.badge.img+10
@Bobby_Gay I had to start the process of creating a new base with Cobuilder and once I did that, Omni started to automatically populate across all of my bases.
arthur__tutt
  • July 1, 2025
In the same boat. The Airtable support article makes it seem like Omni is automatically enabled for all plans.
https://support.airtable.com/docs/using-omni-ai-in-airtable
Arthur_Tutt
  • July 1, 2025
  • July 10, 2025
Thanks Aurthur_Tutt! I went to the link you recommended, selected the “Try it Now” button and Omni appeared. Very cool.
