Automated emails with unique sender name, not with sender name "Airtable Automations"
I sat up an email automation with Airtable. It works well and sends the emails, but I can't find a way to customize the sender name. I'd like to have the company's name as sender name instead of "Airtable Automations". Do you know how I can solve this? I have the Airtable Pro account.
Thanks very much in advance and have a nice day.
Kind regards,
Alex
I think this might be the best we can do I'm afraid:
And I set that up by setting the "From name" after clicking "Show more options":
Forum|alt.badge.img+10
  • 36 replies
  • April 12, 2023
Hi, you cannot do that with Airtable automations, you should use a third-part app like Make.com or Zapier using a module app like Gmail or other email app.
Forum|alt.badge.img+28
Forum|alt.badge.img+27
  • 6004 replies
  • April 12, 2023
If you have Gmail or Outlook, you can use those actions to send the email instead of the Airtable "Send Email". Then the emails will come from your account instead of Airtable.
