Automation runs successfully, conditions are met, but Actions are not executed
  • July 1, 2022
  • 101 views
Actions are not executed although the conditions are met and the automation is displayed as runs successfully. If I then run the automation again in test, the actions are executed.
Trigger: When a record is updated
Conditional Actions:
  1. Condition:
    IF
    lookup field value contains <text>
    AND
    multiple select field values has any of <selected value>
  2. Find records
    Which meet the condition above.
  3. Update record
    Record ID: <record ID>
    linked field: <List of ‘Airtable record ID’ from step 2>
How can this be?
Best answer by Sebastian_Schul
Hey Sebastian, send me a link to your base and I’ll try to figure this out for you?
Hey Adam,
thanks for your offer, but the base is not public and I can’t share it either for privacy reasons.
I think I have found the error myself in the meantime. It seems to me that it is not possible to use only conditional actions. I have now changed the trigger to when a record matches conditions instead and now it works as expected.
  • July 4, 2022
Hey Adam,
