Create a repeating automation based on a number entered into a field
  • February 18, 2026
  • 63 views
Graham Reed
Forum|alt.badge.img+7
Hello all.
I’m wanting to run an automation that will create x number of new records in a table, where x is a number entered into a field (on another table).
So someone wants 5 new records, the enter 5 into the field, the automation runs 5 times.
I’ve seen this:
But not entirely sure I understand how to implement this!
Help muchly appreciated.
Hm, if you’re comfortable with using a script that would be much more straightforward.  I think I was optimizing for not using scripts back then heh
The idea would be to feed the number value into a script that’ll generate an array with that number of items, then use that array in a repeating group action
I’ve set it up here for you to check out
And here’s how the automation looks with the script:
let {numRecords} = input.config()
let array = []
for (let i = 1; i <= numRecords; i++){
array.push(i)
output.set('array', array)
Forum|alt.badge.img+31
let array = []
array.push(i)
Graham Reed
  • February 19, 2026
Thanks Adam.
I’m not but I’d like to be. So the scrip creates an empty array with the number of records you specified in the field, so that the loop then has an array as a base to iterate through x number of times?
Does this mean the script is a generic ‘create a blank array of x records’ that can be used in different scenarios?
Much appreciated, wanting to learn as much as just using this!
Ah, specifically, it’ll create an array with [1, 2, 3, 4, etc] until it hits the number we want, does that make sense?
Yeap to this too!
Graham Reed
  • February 24, 2026
Just wanted to say thanks again for this Adam, this works perfectly.
