From name doesn’t work in mail automation
  • January 17, 2023
  • 23 views
When the automation send an e-mail, the "From name" field sometimes doesn´t work. Anytimes the from is correct in the received e-mail and sometimes the from field is noreply+automations@airtableemail.com The problem is very important because the recipiente doesn't know the sender. Thanks
Forum|alt.badge.img+13
  • January 19, 2023
Hi Oscar—I've just sent a reply to your support case for this issue so that we can gather more context. Looking forward to getting this resolved for you!
