I need help to send emails with pre-filled forms to users in my base
  • April 29, 2023
  • 107 views
I have a membership base in which I want members to review and update their data with a Form.
I have a formula field which opens the form with  pre-filled records
I created an automation to find records in a view
And then used Send an email to send form to users to fill up
This send one email to 3 users for 3 pre filled forms
How can I send 3 emails, one for each member with corresponding pre-filled form?  Eventually, I would like to send about 200 emails.
Thank you,
Myrna
Best answer by kuovonne
Add a repeating group after your find records action. For the repeating group, use the list created by the find records action. Then in the email action, use the information from the current list item.
  • April 30, 2023
  • April 30, 2023
The repeating group is working just fine.  Thank you so much.  I have a new problem, the prefill is not working when it comes from email because the _ is missing.  I tried using Encode_URL_Component with '&prefill_' but it still drops the _.  Any ideas what to do?  Thanks again
  • April 30, 2023
solved the missing _ using %5F
  • April 30, 2023
Prefilled links are no longer the recommended way of doing this anymore.
The recommended way of doing this is to use Fillout’s advanced forms for Airtable.
Fillout is 100% free and it gives you the built-in ability to update an existing Airtable record with a form — with NO PREFILL LINKS REQUIRED.
More importantly, the reason you never want to use prefilled links with Airtable’s forms is because they come with serious & major downsides that you will want to be aware of:
  1. Critical problem: You will have to continually send out updated prefilled links to your users that always contain the newest data. If the user accidentally clicks on an outdated link, they will be taken to old data in the form. So they would never be able to re-use a link or bookmark a link as an “Update My Account Profile” link.
  2. Airtable does not allow prefilled fields to be LOCKED, meaning that a user can always override a prefilled field (even if it’s hidden). If you need a prefilled field to be locked & hidden, then you can always use Fillout to hide and lock defaults.
  3. Airtable’s prefilled links do not work with all field types… particularly attachment fields or lengthy long text fields that exceed URL limits.
  4. If you need the data to remain private or secure, Airtable’s prefilled links reveal all the data within the link. With Fillout’s links, you get one simple, non-changing link per user that doesn’t reveal any data, and you can even add multiple different layers of security to the form if necessary, including SSO login or email login.
  5. Airtable’s prefilled links still won’t update old records… they always create new records, and then you will need to write an automation that handles the overwriting of the old data.
  6. You lose all the advanced features of Fillout’s forms.
So, instead of using prefilled links, simply use Fillout’s advanced forms for Airtable because no prefilled links are required — you can simply update an existing Airtable record using a form.
And in those circumstances when you’re NOT trying to update an existing Airtable record but you still need to prefill a form, Fillout gives you 4 other ways to prefill a form — for a grand total of 5 different ways to prefill a form. And best of all, no prefilled links are required for 4 of these 5 methods.
Fillout is 100% free, and it also offers hundreds of other advanced features that Airtable’s native forms don’t offer, including the ability to create custom PDF files from a form submissionaccept payments on formspre-fetch dynamic data from an Airtable recordcustomize the style and branding of your formcustomize a theme for your form, display Airtable lookup fields on forms, create new linked records on a formadd a login page to your form, perform math or other live calculations on your forms, collect signatures on a form, create multi-page forms with conditional paths, connect a single form to dozens of external apps simultaneously, add CAPTCHAs to your form, and much more.
Hope this helps!
