I need help with Scripting
  • April 7, 2023
  • 30 views
nshnv
Hi Airtable community,
My script is taking too much time to complete and going over 30 seconds limit. I would appreciate if you could review it and give me some tips. Here's the code:
let emailSendersTable = base.getTable("Emails to clients"); let listingsTable = base.getTable("Listings"); let emailSendersQuery = await emailSendersTable.selectRecordsAsync(); let updateBatchSize = 50; let recordsToUpdate = []; for (let emailSender of emailSendersQuery.records) { if (!emailSender.getCellValue("Budget") || !emailSender.getCellValue("Size") || !emailSender.getCellValue("Area") || !emailSender.getCellValue("Layout") || !emailSender.getCellValue("Features")) { continue; } // Access client requirements directly from the "Emails to clients" table let budgetValue = emailSender.getCellValueAsString("Budget"); let budgetRange = budgetValue.match(/(?:~\s*)?¥(\d+,\d+)(?:\s*-\s*¥(\d+,\d+))?(?:\s*~)?/); let minBudget = 0; let maxBudget = Infinity; if (budgetRange) { if (budgetRange[1] && budgetRange[2]) { minBudget = parseInt(budgetRange[1].replace(/[^0-9]/g, "")); maxBudget = parseInt(budgetRange[2].replace(/[^0-9]/g, "")); } else if (budgetRange[1] && !budgetRange[2]) { if (budgetValue.startsWith("~")) { maxBudget = parseInt(budgetRange[1].replace(/[^0-9]/g, "")); } else if (budgetValue.endsWith("~")) { minBudget = parseInt(budgetRange[1].replace(/[^0-9]/g, "")); } } } let size = emailSender.getCellValue("Size") ? emailSender.getCellValue("Size").name : '0m²'; let sizeValue = parseInt(size.match(/(\d+)m²/)[1], 10); let areaValues = emailSender.getCellValue("Area") ? emailSender.getCellValue("Area").map(area => area.name) : []; let areaValuesInListings = areaValues.map(area => area + "-ku"); let layoutValue = emailSender.getCellValue("Layout") ? emailSender.getCellValue("Layout").name : null; let featuresValues = emailSender.getCellValue("Features") ? emailSender.getCellValue("Features").map(feature => feature.name) : []; let isPetAllowedRequired = featuresValues.includes("Pet allowed"); let sixDaysAgo = new Date(); sixDaysAgo.setDate(sixDaysAgo.getDate() - 10); let listingsQuery = await listingsTable.selectRecordsAsync({ view: "NEVER TOUCH THIS VIEW! 2", fields: ["Monthly rent", "Size in m²", "Area (ku and district)", "Layout filter", "Features", "Created date", "Clients (Send emails)"] }); let filteredListings = listingsQuery.records.filter(record => { let monthlyRent = record.getCellValue("Monthly rent"); let sizeInSquareMeters = record.getCellValue("Size in m²"); let listingAreaValues = record.getCellValue("Area (ku and district)") ? record.getCellValue("Area (ku and district)").map(area => area.name) : []; let listingLayoutValue = record.getCellValue("Layout filter") ? record.getCellValue("Layout filter").name : null; let listingFeaturesValues = record.getCellValue("Features") ? record.getCellValue("Features").map(feature => feature.name) : []; let isListingCreatedWithinLastSixDays = record.getCellValue("Created date") && new Date(record.getCellValue("Created date")) > sixDaysAgo; let hasMatchingArea = areaValuesInListings.some(area => listingAreaValues.includes(area)); let hasMatchingLayout = layoutValue ? listingLayoutValue === layoutValue : true; let hasPetAllowed = isPetAllowedRequired ? listingFeaturesValues.includes("Pet allowed") : true; return ( monthlyRent > minBudget && monthlyRent < maxBudget && sizeInSquareMeters > sizeValue && hasMatchingArea && hasMatchingLayout && hasPetAllowed && isListingCreatedWithinLastSixDays ); }); let latestSevenListings = []; for (let i = 0; i < 7; i++) { if (filteredListings.length === 0) { break; } let latestListing = filteredListings.reduce((latest, record) => { return record.getCellValue("Created date") > latest.getCellValue("Created date") ? record : latest; }); latestSevenListings.push(latestListing); filteredListings = filteredListings.filter(record => record.id !== latestListing.id); } for (let listing of listingsQuery.records) { let currentSendEmails = listing.getCellValue("Clients (Send emails)") || []; let filteredSendEmails = currentSendEmails.filter(sendEmail => sendEmail.id !== emailSender.id); let updateData; if (latestSevenListings.some(l => l.id === listing.id)) { updateData = [...filteredSendEmails, { "id": emailSender.id }]; } else { updateData = filteredSendEmails; } recordsToUpdate.push({ id: listing.id, fields: { "Clients (Send emails)": updateData } }); if (recordsToUpdate.length >= updateBatchSize) { await listingsTable.updateRecordsAsync(recordsToUpdate); recordsToUpdate = []; } } } if (recordsToUpdate.length > 0) { await listingsTable.updateRecordsAsync(recordsToUpdate); }
Alexey_Gusev
Forum|alt.badge.img+25
on a quick view:
move that query outside the main loop (i think, it better to be placed at the  beginning part, under the first query)
let listingsQuery = await .....
remove this piece:
Modify the code outside the main loop in the end of script to update by batches according to updateBatchSize limit.
In common, typical Airtable script is:
- get/define input data
- transform it into array of output data
- write output data to the table
for loop is a part of 'transform'. So, all await select... must be located before it, and await updateRec.. - after
