Problem with Airtable to Slack that used to work fine
  • September 10, 2024
  • 46 views
I have a very frustrating problem that started last week. I have an automation that when a record is created a slack message is sent to a slack channel attached to the record. It fails every single time but if i test it it works perfectly every time. It worked until last week and now fails eery time. Any suggestions
Forum|alt.badge.img+31
Try simplifying the automation to debug it?  Specifically, duplicate the automation and make it only send the new record's URL and see whether that works.  If it does, slowly add in the other fields you're using until it fails to identify the cause
If you could provide screenshots of the automation setup and the relevant fields of the base that'd be helpful!
