Repeating group - error on one script doesn't generate error for automation
  • April 25, 2025
  • 88 views
Forum|alt.badge.img+10
I have a script that is using a repeating group to batch process a couple of records sent through output.set() If one of the scripts fails it doesn’t seem to register that error in the overall automation. See image below, individual script failed, overall automation is giving me the green light. I noticed that the script wasn’t behaving correctly on some records but having the script not throw errors is potentially dangerous as problems stay hidden.
Forum|alt.badge.img+31
Hm, do you have a try catch in your code?  If you do have a try catch, try putting in a `throw` to get it to error out the way you want
If you don’t have a try catch set up, could you provide your script for troubleshooting purposes?  Scripts error out fine for me generally, even in repeating groups
  • April 26, 2025
 The repeating group code is too big to paste here but I have the code below which is also not thowing an error even though I am throwing an error. Sometimes I’m wrapping my code in a seperate function so code in nested try catch blocks are being caught.
As you can see in the image its giving me the thumbs up but there is an issue that needs to be addressed and the script is thowing a console.error
try {
// STEP 0: Input from config
const { userRecordId, recordId } = input.config();
if (!userRecordId) throw new Error("Missing required input: userRecordId");
// STEP 1: Define Tables
const userPreferencesTable = base.getTable('user_preferences');
const objectClassesTable = base.getTable('object_classes');
// STEP 2: Fetch user_preferences record for current user
const userPrefQuery = await userPreferencesTable.selectRecordsAsync({
fields: ['user', 'project'],
const userPrefRecord = userPrefQuery.records.find(
(record) => record.getCellValue('user')?.id === userRecordId
if (!userPrefRecord) throw new Error('No user_preferences record found for this user.');
const project = userPrefRecord.getCellValue('project');
if (!project) {
throw new Error('Missing project in user_preferences.');
// STEP 3: Prepare fields to create record
const newObjectClassFields = {
project: [{ id: project[0].id }],
assembly_objects: [{ id: recordId }],
// STEP 4: Create the new record
const newObjectClassId = await objectClassesTable.createRecordAsync(newObjectClassFields);
console.log(`✅ Created new object_class with ID: ${newObjectClassId}`);
console.log("🎉 Script completed successfully.");
} catch (error) {
console.error(`❌ Error in script: ${error.message}`);
Could you try adding a ‘throw’ after the ‘console.error’?
  • April 28, 2025
You mean a final throw errow after the last catch block?
Yeap
