Script to send a Webhook containing field from specific View
  • April 21, 2023
  • 85 views
Hi everyone!
This Script is working greate to send a webhook containing table fields in an automation.
I'm trying chaneg it to send a only fields from a specific view.
I tried to change and adjust it to fit a certain View. I added "let view = table.getView("MyView");" and changed all the Table References to View References but I get an error message:
"TypeError: Cannot read properties of undefined (reading 'length')".
As I am new in coding, Can you tell what is missing?
Best answer by kuovonne
In scripting, a view does not have a “fields” property listing the visible fields. Thus the lines containing view.fields.length and view.fields[i] won’t work.
You will need to hardcode the list of fields that you want.
  • April 21, 2023
That is what I tried:
let table = base.getTable("MyTable");
let webhookUrl = "https://hook.eu1.make.com";
let inputConfig = input.config();
console.log(inputConfig);
let queryResult = await view.selectRecordsAsync({});
console.log(queryResult);
let record = queryResult.getRecord(inputConfig.recordID);
console.log(record); let recordObject = {};
for (let i = 0; i < view.fields.length; i++) { recordObject[view.fields[i].name] = record.getCellValueAsString(view.fields[i].name) } console.log(recordObject);
let response = await fetch( webhookUrl, { method: "POST", headers: { "content-type": "application/json" }, body: JSON.stringify(recordObject) } );
  • April 21, 2023
  • April 21, 2023
OK I undertand a bulk field view export is not possible.
@kuovonne thank you very much!
