'Add Record' blocks primary field display
Primary field 'Total' pick list choices at the bottom is blocked by the '+' sign for add records.
When I hover over the area to the right of the total 312 records number in this base an area behind the '+' sign is also displayed or highlighted, but I can't see what is there. Any suggestions?
Thank you.
Be the first to reply!
