Changing Many Field Widths to a Standardized Width
  • March 30, 2022
  • 253 views
Hello All,
Essentially, is there a way to set the column widths in a view other than clicking and dragging each separate one?
I have to change the width of something like 10 fields across 50 views, and I’d rather not have to click and drag 500 fields individually. Especially since they all should be a standard width.
I’ve looked around online and haven’t found anything - but if you know of a solution, you’d save me a lot of time.
Best answer by ScottWorld
I have clients that would like this ability as well. I would submit this as a feature request to support@airtable.com.
  • March 30, 2022
  • March 30, 2022
Thanks so much! It would be a great feature.
  • February 16, 2023
Can someone please provide a valid link to the solution? The highlighted one is not working and only takes me back to the above email thread without any solution.  Thanks!
  • March 10, 2023
There isn't one as far as I can tell apm. The previous posts are requesting it as a feature.
  • April 19, 2023
You can do it using the API (docs) or Code Extension. I can provide an example if needed, let me know.
