Help needed: struggling to filter records from a lookup field in Airtable
  • February 15, 2026
  • 25 views
Hellen54302
Hi everyone! šŸ‘‹
I’m fairly new to Airtable and I’ve been trying to build a base where I can filter records based on values in a lookup field, but I can’t seem to get it working the way I want. I’ve read some community posts and tried a few different approaches, but I’m still stuck — so I thought I’d ask here for guidance. 😊
Here’s what I’m trying to do:
šŸ”¹ Base setup
  • Table A: Projects
    – Contains project names and related client.
  • Table B: Clients
    – Contains client details + a lookup field in Table A.
  • In Table A, I have a lookup field that pulls the client industry from Table B.
šŸ”¹ Goal
I want to filter Table A to only show projects where the client’s industry includes the word ā€œTechnologyā€.
I’ve tried:
  • Setting a view filter in Table A → Lookup Industry contains ā€œTechnologyā€
  • Creating a formula field referencing the lookup
  • Adding a rollup field
But none of these filters ever show the expected records when I test it. I suspect I might be misunderstanding how lookup values behave in filters vs formulas.
Questions
  1. Is there a recommended way to filter on a lookup field like this?
  2. Should I use a formula that converts the lookup to text first?
  3. Are there limitations with lookup values in Airtable filters that I should know about?
Thanks so much in advance! Any suggestions or sample formulas that might help would be greatly appreciated. šŸ™
  • February 16, 2026
If you have a lookup field that results in text (for example, you’re not looking up a date field), you should be able to filter on that lookup field by clicking on the filter button, choosing ā€œcontainsā€ for the operation, and then typing in the text you’re looking for.
You shouldn’t need to create a formula to accomplish that.
If you’re still having problems, can you post a few screenshots of the problem that you’re experiencing?
