Help with formula to calculate daily percentage increase?
  • March 14, 2020
  • 46 views
Can someone help me write a simple formula for the following problem? I have a 3 column table. First column is the date, second column is the # of cases. 3rd column is the increase % of cases. I simply want to take today’s case value and find the increase from yesterday’s. How do I reference yesterday’s cases? How can I write a formula like this? ((todayCases - yesterdayCases) / yesterdayCases) * 100
Mohamed_Swella1
Hi @Greg_Jellin,
Welcome to Airtable Community !
The short answer is you cannot directly do such formula. Airtable formula fields references fields (columns) not records (rows).
The long answer, there is a work around that you can do. Check this base which I put quickly together. If you need help with it let me know.
BR,
Mo
