Making a field dependent on another
  • May 8, 2020
  • 126 views
Hi!
I am new to Airtable. I am currently setting up an Airtable spreadsheet and one field (column) has a date. Is there any way possible to make the column next to it show what date it will be 2 weeks later?
Regards,
Sam
Best answer by andywingrave
This is the field/column to use:
Replace the word “date” with your field
Hey! Yep - You can use a formula:
DATEADD(Date, 14, 'days')
  • May 8, 2020
How would I tell the system which column to add it from @andywingrave? It says that it is not valid.
  • May 8, 2020
