Max Number of Automations in a Base
  • August 7, 2020
  • 59 views
I was adding Automations to a base, and it says “This base already has the maximum number of automations.” I have not read about this problem anywhere else. Is there any way to increase the max number of automations? I need about 10 more automations.
Thanks.
  • August 7, 2020
How many automations do you have? I didn’t realize that there was a limit, either.
Each automation can only have a maximum of 25 actions, but I didn’t realize that automations themselves had a maximum.
You may want to submit feedback on that here:
If you need more automations, you may need to turn to Integromat or Zapier.
@Vedant_Tapiavala Checking to see if you’re able to share more info based on @ScottWorld’s questions. I’m also unaware of a cap on the number of automations that can be added to a base.
