Why Number fields keep removing the leading number zero?
  • May 30, 2024
  • 158 views
Forum|alt.badge.img+8
I have a number field, no formula related, just simple number field. I have been trying to type 0210, it shows 210 instead, the leading "0" is automatically missing, is there anyway that I can keep the 0? thanks
Forum|alt.badge.img+24
  • May 30, 2024
Leading zeros are removed in number fields.
You may use the Single line text field.
Or use this formula to convert a number field.
REPT("0", 4-LEN({Number}&"")) & {Number}
