Blocks SDK / Interface extensions SDK - Issue on Chrome when developing locally
  • October 30, 2025
  • 147 views
Hi! I get a “Connection error. Please check if your local block is running.” when running the extension I created locally. It works on Firefox. This was working previously. Initially, I thought it was related to a Windows 11 update that broke development with localhost, but I rolled it back, and it works on Firefox…
I’m using the latest build as I plan on using the new multi table feature (I’m currently using the Web API to query a second table).
Taha-Jiruwala
Forum|alt.badge.img+9
If it’s working on Firefox, it should normally work on Chrome as well since the block runs locally through localhost during development. So there shouldn’t be a browser-specific issue.
Make sure you’re running block run before testing so the extension is active locally.
If the issue persists, could you share a few screenshots of what you’re seeing? That’ll help me understand what’s happening.
Taha, Views And Bases
  • November 2, 2025
Yes, I’m running block run, otherwise, it would not work on Firefox. Looking at the browser console, I noticed some CORS errors when trying to get data from localhost.
I then ran Chrome from the command line using the command below (I’m on Windows), and it worked. It seems that the newer version is enforcing CORS? Am I missing something? Looks like Firefox is more lenient?
"C:\Program Files\Google\Chrome\Application\chrome.exe" --disable-web-security --user-data-dir=C:\chrome-dev-data
