Converting a VueJS project to an interface extension (aka inside React)
  • November 21, 2025
  • 148 views
Forum|alt.badge.img+10
I’m loving interface extensions so far! It’s super easy to get up and running. I have an external website that uses the Airtable API that I think would work much smoother if it were an interface extension and inside AT proper. The only problem is… it’s in Vue, and it’s way too complicated a project to rewrite from scratch in React.
Assuming the interface extensions team isn’t planning on making a Vue SDK as well (...unless? 😳), has anyone tried inserting a Vue component into React, specifically inside the Airtable Blocks SDK, where no Vite config file is available?
GCheung
  • Community Manager
  • January 16, 2026
Hey ​@thelus, because your question hasn't yet received an answer/solution from the Community, we've created a Support Case on your behalf with our Airtable Expert Team to get you the quickest response possible. Please check your email for follow-up and your case reference number—and continue to follow this thread as new community members tend to share answers and add knowledgeable responses regularly. Thanks!
MaddieJ
Forum|alt.badge.img+25
  • Community Manager
  • February 3, 2026
Hey ​@thelus just closing the loop here as I believe our Support team was able to help you out. Thanks for being a member of the Community!
