How to get more than 100 rows using Airtable API in Python using offest?
  • May 30, 2020 2:03 AM UTC
  • 194 views
Hello.
I am really new to the Airtable API and for some reason connecting the API this way did not work-
    at = airtable.Airtable('Base_Key', 'Airtable_Key')
But I got it working this way -
get_url = ‘https://api.airtable.com/v0/BASE_ID/TABLE_NAME’
get_headers = {
‘Authorization’: ‘Bearer API_KEY’ }
Response = requests.get(get_url, headers=get_headers)
Response_Table = Response.json()
However, this fetches only the first 100 records and am reading about offset and pagination but I am unable to figure how to incorporate it into this code.
Thank you for the time!
Best answer by Krishangi_Goswa
Update :
I am trying this way -
get_url = 'https://api.airtable.com/v0/appXXXXXXXXXX/TABLE_NAME'
get_headers = {
    'Authorization': 'Bearer keyXXXXXXXXX' ,
    'Offset' : 'itrXXXXXXX/recXXXXXXX'
try :
    Response= requests.get(get_url, headers=get_headers})
    #print(Response_Table)
except error as e:
    print(e)
And I get the error :
{'error': {'type': 'INVALID_OFFSET_VALUE', 'message': 'The value of offset ‘itrXXXXXX/recXXXXXX’ is invalid'}}
I would appreciate any leads. Thank you!
After a lot of issues, I found this solution.
Posting it for anyone else facing the same problem.
global offset
offset = '0'
result = []
while True :
    url = "https://api.airtable.com/v0/BASE_ID/TABLE_NAME"
    querystring = {
        "view":"Published View",
        "api_key":"YOUR_KEY",
        "offset": offset}
    try :
        response= requests.get(url, params=querystring)
        response_Table = response.json()
        records = list(response_Table['records'])
        result.append(records)
        #print(records[0]['id'] , len(records))
        try :
            offset = response_Table['offset']
            #print(offset)
        except Exception as ex:
            #print(ex , offset)
            break
    except error as e:
        print(e)
Thank you!
Update :
get_headers = {
try :
except error as e:
    print(e)
Update :
get_headers = {
try :
except error as e:
    print(e)
global offset
offset = '0'
result = []
while True :
    querystring = {
        "offset": offset}
    try :
        try :
            #print(offset)
            #print(ex , offset)
            break
    except error as e:
        print(e)
Thank you!
