Power BI Connector Error
  • December 6, 2023
  • 253 views
Hi All
I am trying to connect to airtables through power bi and have the API setup with the key, base id and table id. however when i enter the details into Power Bi i get an "We couldn't authenticate with the credentials provided. Please try again." error. now sure why as i do have access to the airtable with the same power bi credentials.
Thanks
  • January 26, 2024
was facing the same issue. just solved it on my end. chat gpt provided a different method than what was described in their documentation. hope this helps!
  1. Open Power BI and Navigate to 'Get Data':
    • Open Power BI.
    • Go to "Home" > "Get Data" > "More".
  2. Choose the Web Connector:
    • Under the "Other" category, select "Web".
    • Click "Connect".
  3. Use the Advanced Option:
    • In the window that opens, switch to the "Advanced" tab.
  4. Enter the API URL:
  5. Add Headers for Authentication:
    • In the "HTTP request header parameters" section, add a new header.
    • Set the "Key" to Authorization and the "Value" to Bearer [Your Personal Access Token].
    • Ensure you replace [Your Personal Access Token] with your actual token.
  6. Confirm and Connect:
    • Click "OK" to confirm the settings.
    • Power BI will now attempt to connect to Airtable using the specified URL and header for authentication.
  7. Load and Transform Data:
    • Once the connection is successful, you can load and transform your data as needed in Power BI.
  • November 4, 2024
    • Open Power BI.
    • Click "Connect".
Hi there,
I followed the method above and it worked, but I guess it will be great if above can be updated into the manual of Airtable.  As the method introduced was quite different against the original way in the https://support.airtable.com/docs/en/visualizing-airtable-records-in-microsoft-power-bi-power-query
Thank you
  • November 4, 2024
Hi there,
Thank you
Hi @mliu ,
Agreed! The above method worked for me but it does end up disconnecting after about 30 days which requires you to re-authenticate. I finally threw up my hands a few weeks ago and started using Coupler (https://www.coupler.io/). It serves as a bridge between Airtable and Power BI. It's $32/month but for the amount of time saved, it was worth it for me.
