Where to start; using scripting block to POST to an api
  • August 17, 2021
  • 6 replies
  • 141 views
Hello! this is my first time using the scripting block and first time trying to use an API with code (I’ve used lots of no-code tools in the past; Zapier, Integromat etc.)
I want to use a text field in my base to create a ‘tag’ in Toggl using the Toggl api;
The Toggl API documentation looks good, and I think I understand most of it, but I don’t know how to actually start - what is the first think I need to write?
All the toggl examples start with ‘curl’ e.g.
curl -v -u 1971800d4d82861d8f2c1651fea4d212:api_token \
	-H "Content-Type: application/json" \
	-d '{"time_entry":{"description":"New time entry","created_with":"API example code","start":"2012-02-12T15:35:47+02:00","duration":1200,"wid":31366}}' \
	 -X POST https://api.track.toggl.com/api/v8/time_entries
Is this what I would paste into the script editor?
I assume I need the toggle api url somewhere ( api.track.toggl.com) so the script knows where to get/post the data but I don’t know where or how to add this url.
Can someone please point me in the right direction?
Cheers!
Best answer by kuovonne
You have a syntax error in your body. This is not a fetch issue, but a JavaScript issue in dealing with strings.
The body should be a JSON string but your opening and closing quotes are messing up the string.
First assign the body to a variable before the fetch …
let body = {"tag":
    "name":"Test-Tag",
    "wid":12345
Then in the fetch …
body: JSON.stringify(body),
  • August 17, 2021
You can start with fetch. See the documentation for more info on how Airtable implements fetch. You can also Google how to convert a curl request to a fetch request.
  • August 20, 2021
Thank so much for your help!
Using this tool (cURL to Fetch) it looks like this is the code I should be using:
fetch("https://api.track.toggl.com/api/v8/tags", {
  body: "{"tag":{"name":"Test-Tag","wid":12345}}",
  headers: {
    Authorization: "Basic abc123:api_token",
    "Content-Type": "application/json"
  method: "POST"
However, I get this error:
SyntaxError: Unexpected identifier
on line 1
at o on line 1
at Generator._invoke on line 1
at Generator.F.forEach.u. [as next] on line 1
at u on line 1
at a on line 1
on line 1
on line 1
Looking at the airtable fetch documentation I can’t figure out what this error code is trying to say.
Any ideas?
  • August 20, 2021
let body = {"tag":
    "name":"Test-Tag",
    "wid":12345
Then in the fetch …
  • August 26, 2021
This was really helpful @kuovonne! I’m trying to do something similar: creating a user in Softr when an Airtable user gets created in my table.
I’m so close to getting this working based on your feedback, but I get back a 'Bad Request" that “User email field can’t be empty” even though I’m passing the email from airtable to softr in the script I’m using.
What am I doing wrong here? I can’t figure out how to structure the email field correctly.
let table = base.getTable("results");
let body = {"user":
    "full_name": "John Richardson",
    "Email": "jrichardson@gmail.com",
    "password": "12345678",
    "generate_magic_link": "true",
let response = await fetch('https://studio-api.softr.io/v1/api/users', {
    method: 'POST',
    headers: {
        'Content-Type': 'application/json',
        'Softr-Api-Key': '----------',
        'Softr-Domain': '----.softr.app',
console.log(await response.json());
Andy_Cloke
  • August 27, 2021
let body = {"user":
    method: 'POST',
    headers: {
Hi Jeremy,
The issue is you’ve got a typo. It should be email, not Email.
If you ever get tired of writing API/fetch code, check out Data Fetcher for a no-code way to do it.
  • August 27, 2021
Hi Jeremy,
Lol. That was my first guess, but as I wasn’t familiar with the api, I didn’t want to accidentally lead anyone astray.
