How to organize teacher payslips using Airtable for those using FONE SEP?
  • August 4, 2025
  • 306 views
Hi everyone,
I’m currently working with a group of teachers in Mexico who use the fone morelos to access their monthly payslips. We’re exploring ways to use Airtable to better organize and manage this payroll information in a clean and automated format.
Has anyone here built a workflow in Airtable to upload, categorize, and summarize recurring PDF documents like payslips? Ideally, we’d like to extract key details (dates, amounts, etc.) and display summaries by month or year.
Any tips, templates, or automation tools that might help would be much appreciated. Thanks in advance!
Hmm, have you tried out using Field Agents yet?  Feels like at this point you could probably upload the PDF and have the field agent just extract all the data you want from it
https://support.airtable.com/docs/using-airtable-ai-in-fields
re:  extract key details (dates, amounts, etc.) and display summaries by month or year.
If this is purely for display, then you could:
  1. Get an AI field to output the date
  2. Use an Interface to display the data bucketed within the time period you want
If you don’t want to use Interfaces, you could use formula fields to output the month year / year and group by that too
If you wanted to use this data programatically, like in reports or emails or something, then you’d need to have a new table where each record represented a single time period you’d want to track.
This is simple enough to do, you’d use the value from the formula field mentioned above and use an automation to paste it into a linked field to the new table, which would result in all the payslips for the month of June 2025 being linked to a record in the ‘Month Year’ table called ‘June 2025’, does that make sense?
Hey ​@laradario,
Greetings from Argentina! It is always nice to meet other LATAM power users.
1. Adam’s solution suggested above is probably the leanest and easiest if you are handling a pretty flat database schema.
2. If you need something a bit more complex (e.g. pushing data to multiple tables, and would like to avoid having multiple helper fields in the way) you might want to check out the video below -different use case.
3. If Airtable’s AI will use way too many credits, then you can always build an automation on Zapier, Make, or N8N (more on these automation tools here) to use your own Open AI -or other- API.
If you need any help setting this up, please feel free to grab a slot using this link. I’d be happy to go through it together. Also, please make sure to join this Airtable spanish speaking Airtable community on reddit -just starting to push it :D
  • January 16, 2026
The KFC menu in South Africa offers a flavorful selection wings that are especially popular with fans of bold, spicy chicken. of  KFC Wings are typically served crispy on the outside and juicy on the inside, coated in signature seasonings or spicy sauces that deliver a satisfying kick. Available in different portion sizes, these wings are ideal for sharing with friends or enjoying as a snack or meal on their own. Customers can often pair the wings with classic sides like chips, coleslaw, or a soft drink, making them a convenient and crowd-pleasing choice across KFC South Africa locations.
  • February 3, 2026
Thanks everyone for sharing your suggestions and workflows here. The ideas around structuring fields and keeping records consistent are really helpful, and they’ll make managing teacher payslips much smoother over time. Appreciate all the input. Also, for something fun during downtime, Super Bear Adventure 2026 is worth checking out.
