Appending a comma separated field with values from another field?
  • March 20, 2024
  • 39 views
Hey all! I'm back with a new issue that I'm hoping won't be too hard to solve but I can't seem to find the solution myself. I have two fields that I need to combine. Field 1 contains a variable, such as GKM3, GKM5, etc. Field 2 contains comma-separated values like L16, L17, L18. I have been trying to find a formula to combine the value of Field 1 with each of the values of Field 2. So the output in the 3rd field would be GKM4L17, GKM4L17, GKM4L18.
Unfortunately, when I try a concatenate or substitute function, it only appends the Field 1 value onto the first value in the list, like in Field 3.
I would really appreciate any help!
You can also try:
{Field 1} & SUBSTITUTE( {Field 2}, ', ', ', ' & {Field 1} )
Forum|alt.badge.img+24
  • March 21, 2024
Hi @AaronB,
If Field 2 is a roll-up field, it can be
{Field1}&ARRAYJOIN(values, ", "&{Field1})
Forum|alt.badge.img+31
You can also try:
