Formula combining Help
  • January 19, 2024
  • 50 views
Formula for 1st Column:
IF(IS_AFTER(TODAY(), {MOC Requested}),  DATETIME_DIFF(TODAY(), {MOC Requested}, 'days'))
Formula for 2nd Column:
IF(IS_AFTER(TODAY(), {MOC Requested}),  DATETIME_DIFF({MOC Submitted Date (from Memo of Correction)}, {MOC Requested}, 'days'))
What I would like to have is a formula (preferably in 1 column) that calculates the number of days between the 3rd column and today unless a date has been entered into the 4th column. Then I want it to show the number of days between column 3 and column 4.
I can't find a way to combine my 2 formulas
dilipborad
Forum|alt.badge.img+23
  • January 20, 2024
Hello @LP321
Use this and change field names accordingly.
IF({MOC Submitted},IF(IS_AFTER(TODAY(), {MOC Requested}), DATETIME_DIFF({MOC Submitted}, {MOC Requested}, 'days')),IF(IS_AFTER(TODAY(), {MOC Requested}), DATETIME_DIFF(TODAY(), {MOC Requested}, 'days')))
I hope this helps 👍
If it's helps then mark it as a solution.
  • January 22, 2024
This worked perfectly. Thanks!
