Formula for combining data from two columns when certain conditions are met
  • April 30, 2024
  • 65 views
Hi! I am using airtable to keep track of several types of info connected to individual clients. However, sometimes I need partners/spouses' names to be in the same column. Is there a way to write a formula that only runs when certain conditions are met?
For example, as seen in the picture below, my current formula for IN PROGRESS: Client and Spouse column is
{First Name (from Spouse/Partner)} & ' and ' & ({Full Name})
I would like that formula to run IF there is a spouse, and I would like the IN PROGRESS: Client and Spouse column to only populate info from the Full Name column if there is no spouse/partner.
I tried writing IF statements, but I couldn't figure out.
Thank you!
Does this look right? 
IF( {Spouse name}, Name & " and " & {Spouse name}, Name )
Forum|alt.badge.img+31
  • May 1, 2024
Yes! That worked! Thank you so much!
