Getting NaN in rollup field, stuck on how to fix it
  • May 29, 2019
  • 79 views
I have one table Evals where I have a true or false question that I want to count in another table called Eval Summary. In Evals, I created two formula fields that seem to be working fine:
IF({Would you attend a similar conference next year?}=“True”,1," ")
IF({Would you attend a similar conference next year?}=“False”,1," ")
I’ve linked the Evals to the Eval Summary table with linked field and created a rollup field linking to that table and formula field with SUM(values). But it’s just giving me NaN and I can’t really figure out why.
Any help is appreciated and thanks in advance!
  • May 29, 2019
Get rid of the ‘else’ portion of that statement — that is, the ‘" "’ part the function reads
IF({Would you attend a similar conference next year?}="True",1)
Whenever an expression can be evaluated to either a number or a string, as your examples are, Airtable forces all responses to be text; in other words, you’re not summing 1 + 1, you’re summing '1' + '1'. Since you can’t add text + text, you get the Not a Number error…
  • May 29, 2019
Thanks for your help! I really appreciate it.
