Help with IF and DateTime_Diff
  • October 26, 2023
  • 106 views
IF({Last Renewal},
DATETIME_DIFF(
TODAY(),
{Last Renewal},
'days'
) > 365,
The above formula, without the first {Last Renewal}, works fine. But I have records that are empty and I want them blank. I obviously am not constructing my syntax correctly. I want to say that if {Last Renewal} is not blank, then do the following. as I said it works if take out the first {Last Renewal}. I'm sure it is simple. I just don't see it.
Thanks, Scott
Best answer by jwag
I think you're missing a 2nd if (nested). Try the following:
{Last Renewal},
DATETIME_DIFF(
TODAY(),
{Last Renewal},
'days'
) > 365,
This says: if the renewal date is not blank, then check the date diff, otherwise if it's blank, return blank.
A little clarification, I get a green emoji in the blank record. All else works. This is the formula that works, but has a the green emoji in the blank record.
DATETIME_DIFF(
TODAY(),
{Payment Date},
'days'
) > 365,
Again thanks, Scott
DATETIME_DIFF(
TODAY(),
{Payment Date},
'days'
) > 365,
Again thanks, Scott
Screenshot of result of formula. Need Abernathy records be blank. Thanks ,Scott
Forum|alt.badge.img+13
  • October 26, 2023
{Last Renewal},
DATETIME_DIFF(
TODAY(),
{Last Renewal},
'days'
) > 365,
Fantastic, Thanks! I was thinking that I probably needed another If statement. That worked perfectly. Best, Scott
