Help with if then formula
  • March 8, 2023
  • 77 views
I am needing help creating a formula.
It would be if (15% referral says no then it would calculate the daily rate times 15%), if (15% referral says yes then it would be daily rate)
Best answer by Ben_Young1
Hey @AmandaC1121!
Is this along the lines of what you're looking for?
IF( {15% Referral} = "No", {Daily Rate} + ({Daily Rate} * .15), IF( {15% Referral} = "Yes", {Daily Rate} ) )
It's worth noting that this formula will return nothing if the 15% Referral field returns empty.
If you'd like for the formula to default to just returning the Daily Rate, you could use this:
IF( {15% Referral} = "No", {Daily Rate} + ({Daily Rate} * .15), {Daily Rate} )
You'll want to confirm that your formula field's formatting configuration is set properly:
Ben_Young1
Forum|alt.badge.img+22
Hey @AmandaC1121!
